In my project, I am using LPC2378,keil uV 4,In LPC2378 capable of 512KB Code size,my project have three file, my problem is at the time of build my code linker error occur that is " signal card.axf: error: L6050U: The code size of this image (43828 bytes) exceeds the maximum allowed for this version of the linker".
so I remove some part from coding, and build again,error rectified but code size is 69KB.
pls anyone help me i add some more code to my project.it is possible or not? pls give me solution for above error
You seem to have "forgotten" to tell us which of the different MDK tools you have.
Note the code-size limitations of some of the variants: http://www.keil.com/arm/selector.asp
Are you asking for help to get past an intended code-size limitation?
hi,
I am working with Realview MDK-ARM Evaluation Version,What is the maximum code size for this MDK.pls give the suggestion
Thanks & Regards, S.sathishkumar
Limitations:
http://www.keil.com/demo/limits.asp
hi, From abve, I understand MDK-ARM lite code limitation 32 KB,but I compiled my code it will generate hex file with size 89 KB,how it is created with 89KB hex file , Is above 32KB only for run time code size?if it is correct means I will compile and get hex file with 128kb size from this. pls anyone clarify my doubt
Thanks & Regards Sathish
32KB binary data - if you use "fromelf" (found in your tool chanin folder) you will see that your image is indeed limited in size. .hex files contain a lot of other stuff - record type, checksum, offset etc. that inflate it, in addition to the binary data itself.
.hex files contain a lot of other stuff - record type, checksum, offset etc. that inflate it, in addition to the binary data itself. not to mention that every byte of code uses 2 bytes in .hex
hi, I understood all,I am working with MDK-ARM evaluation version,it's limitation 32kb code size.if I will increase my code,will I use RVDS 4.1 VERSION,Anyone give the solution
"Anyone give the solution"
Give solution to what?
