Calling Assembly Function From Another File
I have two files in my project, that are as follows;
///////////////////////////////////// File 1 //////////////////////////////
$NOMOD51
$INCLUDE (REG952.H)
PUBLIC HI_DATA
PUBLIC LO_DATA
PUBLIC LED_PORT
PUBLIC RAM_LOCATION
EXTRN CODE (init_CAM)
; EQUATES COMMON
LED_PORT EQU P5
USING 0 ;using register bank0 USING 1 ;using register bank1
C_DATA SEGMENT DATA
RSEG C_DATA
HI_DATA: DS 1;
LO_DATA: DS 1;
RAM_LOCATION: DS 1;
STACKPTR: DS 1; ; START OF STACK
; INTERRUPT VECTORS
C_TEXT SEGMENT CODE RSEG C_TEXT
ORG 000H ; RESET VECTOR JMP INIT_MAIN
; INITIALIZATION ROUTINE COMMON
INIT_MAIN:
;---------- added for NXP -----------------
MOV DIVM,#2
MOV DPTR,#0FFB8H ; P4M1 MOV A,#00H MOVX @DPTR,A MOV DPTR,#0FFB9H ; P4M2 MOV A,#00H MOVX @DPTR,A MOV DPTR,#0FFBAH ; P5M1 MOV A,#00H MOVX @DPTR,A MOV DPTR,#0FFBBH ; P5M2 MOV A,#00H MOVX @DPTR,A
MOV P2M1,#00H ; for NXP MOV P2M2,#00H ; for NXP MOV P1M1,#00H ; for NXP MOV P1M2,#00H ; for NXP MOV P0M1,#00H ; for NXP MOV P0M2,#00H ; for NXP MOV P3M1,#00H ; for NXP MOV P3M2,#00H ; for NXP
MOV SP,#STACKPTR MOV LED_PORT,#05H
MOV HI_DATA,#0 MOV LO_DATA,#0 MOV RAM_LOCATION,#0
; BACKGROUND PROCESS
BKGR:
call init_CAM
JMP BKGR
; BACKGROUND PROCESS ends
END
whereas file 2 is
///////////////////////////////////// File 2 //////////////////////////////
$NOMOD51
EXTRN DATA (HI_DATA)
EXTRN DATA (LO_DATA)
EXTRN NUMBER (LED_PORT)
EXTRN DATA (RAM_LOCATION)
PUBLIC init_CAM
LIB_TEXT SEGMENT CODE
RSEG LIB_TEXT
init_CAM: MOV LED_PORT,#0AH
RET
END
Note: When I declare the function init_CAM directly in file 1, the LED_PORT works. However if I call the same init_CAM function created in file 2, the LED_PORT does not work. The code compiles without error. Kindly provide the solution to this problem. I am using uVision 3 VER3.30 and the target controller is NXP P89LPC952.
Regards,
Nick
