I am working on a project wherein LPC2468 is being used with CCLK = 72MHz. With this frequency, I used following two options: >> PCLKSEL1.PCLK_TIMER3 = 0x2 Here the Clock of timer3 runs @ CCLK/2 = 36MHz with a resolution of 27.78ns I load the T3MR0 with 3600d to generate a Interrupt on Timer3 every 100us
>> PCLKSEL1.PCLK_TIMER3 = 0x1 Here the Clock of timer3 runs @ CCLK = 72MHz with a resolution of 13.88ns I load the T3MR0 with 7200d to generate a Interrupt on Timer3 every 100us
The Timer init code is as follows: T3TCR = 0x02; /* Stop the timer */ T3PR = 0x0; /* Set prescaler to zero */ T3IR = 0x01; /* Clear Int flag of MR0 */ T3MCR = 0x03; /* Interrupt is generated when MR0 matches TC and TC is cleared */ T3MR0 = /* 3600 or 7200 depending on if I choose Option 1 or Option 2 */ T3TCR = 0x01; /* Start the timer */
Other Setting includes >> PCONP.PCTIM3 = 1 >> Interrupts being configured through VICIntEnable registers.
Requirement: I need to collect the data sent over the USB ( 56bytes per USB frame ) and then at every 100us, I need to transmit it in a form of a CAN message, for this I am using Timer3 to generate an Interrupt for me at every 100us, since other Timers Timer0/1/2 are used up by other applications.
Obtained Result: I am capturing the CAN message over a CANalyzer and I see that minimum recurrence during which I get the CAN message is 240us. Any ticks values equalent to time >=240us loaded in T3MR0, works fine but not the values for <240us
I need assistance for this issue. During this operation interrupts related to USB rx, CAN tx and Timer 3 are enabled.
I want to know what I have missed in my code due to which I am not able to generate Timer03 interrupt.
Do you support nested interrupts?
Have you checked the function of this timer interrupt (for example driving a GPIO pin) when you _only_ have timer 3 enabled to generate interrupts?
Next thing - are your only validation of the timer interrupt the repeat frequency of CAN frames? What speed are you running the CAN interface at? 10k frames/second is a very high bus load. And what size are each CAN frame?
I think your problem isn't timer3 but the max speed you manage to get the CAN controller to send out frames.
