I want to select a new ARM controller for my project. I am thinking of going for LPC2103 which is having 32KB of FLASH and 8KB of SRAM. My code size will be less than 32KB, but I am not sure if the SRAM of size 8KB be enough. So, I have following queries.
1. What are the criteria for for selecting the controller with correct SRAM? 2. Do the manufacturers take care of this? (because I have observed that as the FLASH size on a controller increases, SRAM size on the controller also increases) 3. What is SRAM exactly used for on the controllers? (Building cache memory is one of the uses I know. What are the other uses?)
Regards, Sagar J.
It's a rather old MCU. I think you'll be better off picking one of the newer Cortex-M based MCU's.
That's easy. You just pick an MCU that has enough SRAM for your application. So the question becomes: "How much SRAM does my application need?"
It's used for storing the variables in your program. In some applications, you'll also allocate some RAM for things like DMA buffers and vector tables.
If you intend to use NXP devices, I'd pick a modern LPC1114 (Cortex M0) which has a comparable flash/RAM size but the advantages of a Cortex.
use the one from the series you intend to use with the largest memory for development, THEN decide.
So you know your ROM size, but not the RAM size --- and both before you've even picked a chip, much less started coding?
I really wonder how you arrived at that belief.
And you think that makes sense?
I really wonder how you could contrive such a meaningless sentence.
Thanks Mike Kleshov! Your answers were very helpful. It's a rather old MCU. I think you'll be better off picking one of the newer Cortex-M based MCU's. The reason I am going for a low end ARM controller is because I have some constraints regarding the cost of my project. Also, I will be using only a few features of the controller. But as you are saying that LPC2103 is an old MCU, I will think of some controller from LPC213x series.
It's used for storing the variables in your program. In some applications, you'll also allocate some RAM for things like DMA buffers and vector tables. I did some R&D on my another project which uses another LPC ARM controller. Though that I came to know the use of SRAM for storing variables. Although, info about allocating for buffers and vector tables was new to me and found it useful.
Thanks again!
Hey Mike,
I just went the features and pricing some of the Cortex-M processors. Prices are well in my range, rather I found those cheaper than the LPC213x series. Thanks for guiding me towards ARM Cortex-M series.
Thanks Tamir! I will surely go through LPC1114 controller.
I have my code ready for LPC214x controller. I was just looking for a less expensive alternate which satisfies my needs for this project. Just wanted to clarify a few doubts before doing the selection and so I posted this question. Anyways, never mind!
Thanks Jeff Malhoon!
(Btw, above post was for Hans-Bernhard Broeker!)
