I am using printf function to send data to serial port. The mcu has to send a number which may be upto 65535.
But for numbers larger than 32767, I was getting negative numbers. To test it I wrote following code
unsigned int i; for(i=32760;i<=32770;i++) printf("%d\n", i); //printf ("char %bd int %d long %ld\n",a,b,c);
What I was getting in VB application is
32760 32761 32762 32763 32764 32765 32766 32767 -32768 -32767 -32766
So I tried the same program in Pelles C for Windows . The result was perfect.
32760 32761 32762 32763 32764 32765 32766 32767 32768 32769 32770 Press any key to continue...
Can somebody tell me what is wrong here?
And when you found you got incorrect [sic!] printouts, you then immediately started to wonder about signed and unsigned numbers, and picked up the documentation for printf() and too a closer look at the available formatting strings?
Does the printf() documentation really suggest that "%d\n" is a good formatting string for unsigned integers? Remember that this is standard C - not anything Keil-specific.
Dear Per Westermark, you are literally reading my mind, as if you were here. I just downloaded printf documentation from byuh.doncolton.com/.../printf.pdf and trying to study the formatting strings.
This is not the first time I have searched for the printf documentation :(
Sorry, I am new to C, just started to code in keil, previously I was using assembly, and finishing my projects somehow. AND I MUST ACCEPT THAT IT WAS ONLY POSSIBLE BECAUSE OF YOU PEOPLE.
Instead of "%d\n", I had also tried
const unsigned char code crlf[3] = {0x0d, 0x0a, 0x00}; printf("%d%s", i,crlf);
I thought it may not be a Keil-specific issue, but as I did not have any problem in Pelles C, I asked here. Please help!!!
Examine the size of an unsigned int. Examine the range of an unsigned int. Examine the differences in size and range of an unsigned int with different compilers and environments. Also, you might want to examine how a value is encoded into an unsigned int anc compare it with how it is done with a signed int.
Then you should easily understand what is happening.
I do not charge for my services and, when I can, I do so for free.
Thanks J Macmillan,
I solved my problem with your free service ;) I used %u instead of %d or %i & I am getting proper results now.
THANKS EVERYBODY!!!
Then you might like some free reference/learing resources for C programming:
blog.antronics.co.uk/.../08
As already noted, the above is all standard 'C' - nothing specifically to do with Keil or C51.
However, there are certain areas which do have issues specific to Keil C51;
eg, see: http://www.keil.com/forum/22199/
You have not been charged for this service.
he he he, Thanks!!!
