I'm using the Embedded Artists development board LPC3250. The flash on it is K9F1G08U0A (1GBit NAND Flash, 3.3V, 8-bit databus) from Samsung. Does anyone have the flash programming algorithm for it? If not, do you know if the .axf file can be treated as a raw binary file and thus loaded through other means? (the only other method I've read about is srec). Any help would be appreciated! Thanks.
No .axf is not raw binary but you can produce .hex file from uVision and then convert it to .bin or you can use froelf on .axf file to produce .bin
