I'm using the MDK v4.21 with the ULink2 for debugging. My problem is, that the uVision crashes as soon as I press the debugging button to start debugging. I use the uVision only for debugging my software via a *.elf (dwarf2) input file. The software is compiled externally via a makefile. I found out, that the debugger does not crash when I disable the "Load Application at Startup" option in the Debug tab within the configurations. As soon as I enable this option, the debugger crashes. The device that I use is the STM32F103ZE on a STM3210E eval board. Crahsing does not depend on the interface (JTAG/SW).
I was already able to debug with my setup. I'm not sure what I have changed that can caused the crashes. When I load a small demo elf-file from the STM Discovery board the environment does not crash.
Any hints what could be the reason for these crashes? Which further informations are needed to find the reason?
Thank you, Ralf Hochhausen
Here are some more detailed infos about my environment:
IDE-Version: µVision V4.21.0.0 Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information: BSH BSH BSH LIC=KRMIR-H85IY-45PKD-6D2UY-UULUB-2UWX9
Tool Version Numbers: Toolchain: MDK-ARM Standard: 8 user Version: 4.21 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.713 Assembler: Armasm.Exe V4.1.0.713 Linker/Locator: ArmLink.Exe V4.1.0.713 Librarian: ArmAr.Exe V4.1.0.713 Hex Converter: FromElf.Exe V4.1.0.713 CPU DLL: SARMCM3.DLL V4.21 Dialog DLL: DARMSTM.DLL V1.62 Target DLL: BIN\UL2CM3.DLL V1.90 Dialog DLL: TARMSTM.DLL V1.60
