I am new to ARM technology. I am using Nxp ARM7 LPC 2368 board.I have tried few of the codes and they are working fine. Please help me out in writing a program which writes data into the memory using digital inputs and outputs. i am not able to configure the timer to 1ms. Please help me out.
Another doubt, sending data over ethernet using TCP/IP protocol. Can someone please suggest me how to proceed and provide me with codes which would help me out.
Use search function on forum, there are a lot of threads that could be usefull to you.
Basically you do want someone else to supply full code. No indication you want to spend own time on the project.
The question then - why did you get involved in the project in the first place?
