typedef uint8_t BDADDR_t[6]; typedef struct { uint8_t State; BDADDR_t RemoteBDADDR; uint16_t DataPacketsQueued; uint16_t Handle; uint8_t LinkType; uint8_t CurrentIdentifier; bool LocallyInitiated; }ATTR_PACKED BT_HCI_Connection_t; BT_HCI_Connection_t HCIConnection;
The address of HCIConnection is:0x1000004E and the memory data start from 0x1000004E is as following: 03 10 a3 15 83 15 00 00. So I think the State = 03; the BDADDR is 00 15 83 15 a3 10, but the watch window show that the BDADDR is 00 00 15 83 15 a3. So what should I do to get the correct value of a mix typed struct?
Another question: Does the effect of #pragma pack(1) is the same as __packed ? Thanks!
chris
No, there are differences. But the effect that you likely care about is the same. You should read the manual for details.
www.keil.com/.../armccref_CJAFEEDG.htm
www.keil.com/.../armccref_CJAFJHJD.htm
So here I need to place linkType behind the State member? Thanks!
Chris
