typedef uint8_t BDADDR_t[6]; typedef struct { uint8_t State; BDADDR_t RemoteBDADDR; uint16_t DataPacketsQueued; uint16_t Handle; uint8_t LinkType; uint8_t CurrentIdentifier; bool LocallyInitiated; }ATTR_PACKED BT_HCI_Connection_t; BT_HCI_Connection_t HCIConnection;
The address of HCIConnection is:0x1000004E and the memory data start from 0x1000004E is as following: 03 10 a3 15 83 15 00 00. So I think the State = 03; the BDADDR is 00 15 83 15 a3 10, but the watch window show that the BDADDR is 00 00 15 83 15 a3. So what should I do to get the correct value of a mix typed struct?
Another question: Does the effect of #pragma pack(1) is the same as __packed ? Thanks!
chris
What you have learned is the important lesson that you should never make assumptions about where a compiler inserts padding in structs - so don't write code that requires such assumptions.
The compiler may decide that the array is of byte type and can be placed at an odd address. And the compiler can decide that having a pad before the array or after the array makes a difference in number of memory accesses needed to access the full size of the array - after all, a non-packed struct requires the following 16-bit member to be aligned.
Remember also that copying of raw data that is sent over a wire or picked up from memory card etc doesn't take into account the byte order for the sender and receiver. And using pragma or other meta-attributes to pack a struct will not take care of incorrect byte order. It is normally best to explicitly pack/unpack data when sharing data over a communication link.
Never say never. Here is a structure from uIP:
struct arp_hdr { struct uip_eth_hdr ethhdr; u16_t hwtype; u16_t protocol; u8_t hwlen; u8_t protolen; u16_t opcode; struct uip_eth_addr shwaddr; uip_ipaddr_t sipaddr; struct uip_eth_addr dhwaddr; uip_ipaddr_t dipaddr; };
This structure is used to access the actual ARP header inside a packet buffer. As you can see, it does assume that the compiler will not insert any padding. You'll be surprised to know how well this works on a wide variety of platforms. But I agree, this should probably be considered a hack.
http://www.keil.com/forum/21537/
somesay no never some say yes. how can we know what is right?
Easy. When you see the word 'never,' replace it with 'this doesn't sound like a good idea, make sure you know what you are doing.'
