I am having a problem with the Keil compiler not performing an optimization that looks trivial. I am using Keil 4.50. The issue can be reproduced with the following simple code:
extern int g(int arg1); extern int extint1; int f( int arg1) { int a; int b; a = g(arg1); b = (int) &extint1 + a - a + 10 -5; return b; }
When compiled with maximum optimization (O2 or O3), I would expect the compiler to optimize away the ‘a-a’ in the computation of b, but it doesn’t. When compiled with –O3 the result is
; generated by ARM C/C++ Compiler, 4.1 [Build 791] ; commandline ArmCC [--list --debug -c --asm --interleave -ocompileroptimization.o --asm_dir=.\ --list_dir=.\ --depend=compileroptimization.d --cpu=Cortex-M3 --apcs=interwork -O3 -IC:\Keil\ARM\CMSIS\Include -IC:\Keil\ARM\INC\STMicroelectronics --omf_browse=compileroptimization.crf CompilerOptimization.c] THUMB AREA ||.text||, CODE, READONLY, ALIGN=2 f PROC ;;;3 ;;;4 int f( int arg1) 000000 b510 PUSH {r4,lr} ;;;5 { ;;;6 int a; ;;;7 int b; ;;;8 ;;;9 a = g(arg1); 000002 f7fffffe BL g ;;;10 b = (int) &extint1 + a - a + 10 -5; 000006 4902 LDR r1,|L1.16| 000008 4401 ADD r1,r1,r0 00000a 1a08 SUBS r0,r1,r0 00000c 1d40 ADDS r0,r0,#5 ;;;11 ;;;12 return b; ;;;13 } 00000e bd10 POP {r4,pc} ENDP |L1.16| DCD extint1
Note the ADD r1,r1,r0 immediately followed by the SUBS r0,r1,r0; not what I expect from an optimizer. Without the presence of extint1, the compiler optimizes correctly. The trivial answer is of course not to write code that does ‘a-a’, but that is not a realistic option in my project. I need to rely on the compiler to optimize this code.
Does anyone have an idea on why the compiler behaves like this and how I can let it optimize this correctly?
One nitpick regarding your post's subject line. Please be aware that the thing you want optimized is not, actually, an initializer expression. It's the right hand side of an assignment expression.
Correct.
