i want timer program to generate pulse using 10khz frequency
here is my code..is it correct.if wrong plz help me to generate pulse of 10khz .
#include <LPC21xx.H>
void T0isr(void)__irq;
void delay(void)
{ VPBDIV = 0x00000002; //Set pclk to 30 Mhz
PINSEL0 = 0x00000020; //Enable pin 0.2 as capture channel0
T0PR = 0x0000001E; //Load prescaler for 1 Msec tick
T0TCR = 0x00000002; //Reset counter and prescaler
T0CCR = 0x00000005; //Capture on rising edge of channel0
T0TCR = 0x00000001; //enable timer
VICVectAddr4 = (unsigned)T0isr; //Set the timer ISR vector address
VICVectCntl4 = 0x00000024; //Set channel
VICIntEnable = 0x00000010; //Enable the interrupt } int main(void) { IODIR0=0X000000001;
while(1)
{ IOSET0=0X00000001;
delay();
IOCLR0=0X00000001;
delay();
void T0isr (void)__irq
{ //static int value;
//value = T0CR0; // read the capture value
T0IR |= 0x00000001; //Clear match 0 interrupt
VICVectAddr = 0x00000000; //Dummy write to signal end of interrupt
