No timer1 interrupt on aduc7020
Hi everyone,
I've already spent 3 days trying to get a timer1 interrupt on an aduc7020, without any success
Timer1 init:
        IRQCLR = GP_TIMER_BIT;
        T1CLRI = 0x55;           // Clear pending interrupts
        T1LD  = (32768/2)-1;            // 32768 clock ticks
        T1CON = BIT9 + BIT7 + BIT6;  // Periodic mode, enable timer, 32768Hz source clock
        IRQEN = GP_TIMER_BIT;   // Enable Timer 1 interrupt
in my main loop:
if(IRQSIG & GP_TIMER_BIT)
GP0CLR = (1 << 16 << 6);
else
GP0SET = (1 << 16 << 6);
perfectly works.
i'm using keil compiler, with the default startup code that clears the I & F flags:
;  Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
;  Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                IF      :DEF:__MICROLIB
my interrupt routine which is never called (led is never set):
void IRQ_Handler(void) __irq
        unsigned long IRQSTATUS = 0;
        IRQSTATUS = IRQSTA;
        if ((IRQSTATUS & GP_TIMER_BIT) == GP_TIMER_BIT)         //Timer 1 interrupt source
                T1CLRI = 0x55;
        GP0SET = (1 << 16 << 4);    //Red on
and my main code blinking a led
while(1)
GP4CLR = (1 << 16 << 2);
for(i = 0; i < 300000; i++)
__nop();
else
GP4SET = (1 << 16 << 2);
__nop();
else
this code works, the led keeps blinking and the other led is set when the irqsig is present. However, the the interrupt setting another led is never launched.
