I use uVision V4.60.0.0 and I trying to flash the hex file with Ulink2 device. The problem is that Keil doesn't allow me to flash .hex without .axf file.
Possible solution to this problem which described here - http://www.keil.com/support/docs/3539.htm doesn't help me, I receive the same error.
BR, Roman
I have the same problem too. I change the Name of Executable to Name.hex, still the target didn't want to build. The Build Output windows keep saying "Name.hex: Error: L6320W: Ignoring --entry command. Cannot find argument 'Reset_Handler'" and "Name.hex: Warning: L6320W: Ignoring --first command. Cannot find argument '__Vectors'". Does someone know how to fix it?
To solve your problem only type name.hex (not only name) in Options for Target -> Output -> Name of Executable textbox.
