I have a question about how or when configure interrupts using RTX in unprivileged mode, The question is: 1 - What happens if the program goes into an interrupt which uses OS directives before the OS is initialized?
I'm using a MDK-ARM + ver4.53 STM32F4 and this is a piece of pseudo code to illustrate my doubt.
int main(void) { //initialize the timer to generate an interrupt every 1ms TIM4_Config(); PeriphX_Config(); // All peripherals generate interrupts PeriphY_Config(); // PeriphZ_Config(); // // What happens if the program takes more than 1ms to reach this point? os_sys_init(task1); } __task void task1(void) { while(1){ //Wait event os_evt_wait_or (0x0008, 0xFFFF); // do something } } void TIM4_IRQHandler(void){ //Send event isr_evt_set (0x0008, task1); TIM_ClearITPendingBit(TIM4, TIM_IT_Update); }
