Recursion in embedded system
Can anybody give an insight whether this is good or not in embedded environment?
I have a function which call itself when a condition is false, see code sample below:
void Test(void)
   U8 temp;
   U8 temp1;
   U16 temp2;
   U16 temp3;
   if(some_extern_flag)
      //Exit to this function
   else
     Test();   //Call me again
Does it create memory leak when called many times, say 5 times the flag is false, it will call itself 5x?
This function doesn't called from either ISR or other function, just within it.
Will this create a problem later on?
thanks
gp
