Can anybody tell me what is wrong in the following coding? I am unable to set P1.5 and P1.6 if I take the set memory from the variable and try to assign it to P1.5 or 6. But I am able to set P1.5 and 6 if directly assign from the saved debounce variable. Here below is the code.
#include <reg51.h> #include <stdio.h> #define bitset(a,b) ((a)|=(1<<(b))) #define bitclear(a,b) ((a)&= (1<<(b))) sbit LEDp17 = P1^7; sbit LEDp15= P1^5; sbit LEDp16=P1^6; sbit LEDp14=P1^4; sbit PB0_0 = P0^0; sbit PB0_1 = P0^1; static char bdata ibase; sbit pb00 = ibase^0; sbit pb01 = ibase^1; sbit firstscandone = ibase^2; sbit testbit1 =ibase^3; sbit testbitp15 = ibase^5; sbit testbitp16 = ibase^6; void delay1(int counts) { int i, j; for(i=0; i<1000;i++) for(j=0; j<counts; j++); } void init1(void) { delay1(20); P0=0xff; P1=0x00; P0=0x00; P1=0x00; ibase=0; //firstscandone=1; //bitset(ibase,2); testbit1=1; } void debounce(void) { int x, y; if(PB0_0==1) { for(x=0; x<5; x++); if(PB0_0==1) { pb00=1; pb01=0; } } if(PB0_1==1) { for(y=0; y<20; y++); if(PB0_1==1) { pb01=1; pb00=0; } } } void main(void) { if(firstscandone==0) init1(); while(1) { debounce(); if (pb00==1) { bitset(ibase,5); delay1(10); bitclear(ibase,6); } if(pb01==1) { bitset(ibase,6); delay1(10); bitclear(ibase,5); } if(firstscandone==1) bitset(P1,4); if(testbitp15==1) bitset(P1,5); else bitclear(P1,5); if(testbitp16==1) bitset(P1,6); else bitclear(P1,6); //When any of P0.0 and P0.1 is switched on then P1.5 or P1.6 are not getting on but P1.4 goes off. bitset(ibase,2); } }
for bit clearing use,
byte &= (~(1<<(bitposition)))
why do you not use the much more efficient bit instructions
you have sbit LEDp14=P1^4;
instead of bitset(P1,4); use LEDp14 = 1;
you gain clarity (the symbolic bit name instead of a '4') and efficiency.
have a look at the generated assembler for the two, the difference is HUGE.
PS to the homewrecker: if you want to spew bile, do not say "other exist" list them
"why do you not use the much more efficient bit instructions"
for reasons apparently impossible for you to comprehend.
