Strange Way to Code
I came accross this code fragment when reviewing some sample code for ethernet. Didnt even try to build it. Would the delay function even be called if no executable code is in the body? I would think it would be optimized out under all circumstances? In my opionion, its not the right way to do it anyway...
Just curious ...
static void delay (void) {;};
/*--------------------------- output_MDIO -----------------------------------*/
static void output_MDIO (U32 val, U32 n) {
   /* Output a value to the MII PHY management interface. */
   for (val <<= (32 - n); n; val <<= 1, n--) {
      if (val & 0x80000000) {
         GPIO2->FIOSET = MDIO;
      else {
         GPIO2->FIOCLR = MDIO;
      delay ();
      GPIO2->FIOSET = MDC;
      delay ();
      GPIO2->FIOCLR = MDC;
  • Would the delay function even be called if no executable code is in the body? I would think it would be optimized out under all circumstances?
    Not under any circumstances. Under most, probably.
    That's interesting, though: what's a portable way of creating a short delay? Reading a dummy volatile variable, maybe?
