hello, i am working on a 8051 controller..i have to display a certain message on a particular location on the terminal...is there any function through which i can set the cursor position..??or any other method for doing this??
This is done with escape sequences:
ascii-table.com/ansi-escape-sequences-vt-100.php
how can this be implemented??could you elaborate??i was referring to a PC serial hyper terminal...
Sorry, who is actually supposed to be doing this work...?
"how can this be implemented??"
www.8052.com/.../160143
"could you elaborate??"
www.lmgtfy.com
"i was referring to a PC serial hyper terminal"
Do you think it makes any difference to the PC whether the commands come from an 8051, or anything else...?
Console windows in Windows versions do not support ANSI escape sequences at all..
