Static declaration error
Code: static unsigned int timer[num_timers];
Error: TIMER_MODULE.C(6): error C221: non-constant case/dim expression
An error has been generated while declaring an array in static.
Or else help me out with " an initial value of the array's element should be zero." what should I do?
