How do I display a memory map of my variables and their addresses?
I am looking through the .map file but I cannot see a final memory map of all the variables. Is there a way to do this with Keil?
regards
Konrad
Which toolchain are you using?
For MDK, Options for Target>>Listing, check Linker Listing and then check Symbols. Rebuild your project and browse .map for Image Symbol Table.
thanks,
Note that you won't get automatic variables in the linker map...
Thanks, I had missed that auto variables would not appear, doh!
I am just starting with the ARM (STM32F4). I am doing some basic testing like cheking the speed of interrupts.
I had some variables declared as volatile in an interrupt routine and assumed they would then be global and I could see them. Re-declaring them as static showed them in the memory map. Changing them from automatic to static atually had a detremental impact on the speed.
Regards
No - volatile has nothing to do with scope or lifetime!
"Re-declaring them as static showed them in the memory map. Changing them from automatic to static atually had a detremental impact on the speed"
When they were automatic, they might have been in registers?
But did you actually want them to be global...?
