Hi all, I'm trying to make an interrupt on one pin of the port 2. I found the registry setting, but I do not know the name of the interrupt function.
For an interrupt EXT1 the name of the function is "void ext1_int (void) __ irq". For an interrupt on port 2, how should I do? Where I put my routine interruption?
Thank you for your help :)
What gave you the impression that interrupt handlers had predefined names?
Hello, I have make a test and I think i Have found the solution:
void init_interrupt_channel(void) { LPC_GPIO2->FIODIR &= ~(1<<5); /* EINT1 as input */ LPC_GPIOINT->IO2IntEnF |= (1<<5); /* Enable falling edge irq 2.11 */ NVIC_EnableIRQ(EINT3_IRQn); /* enable irq in nvic */ } /*---------------------------------------------------------------------------- * External Interrupt PORT 2 Service Routine: Digital Channel *---------------------------------------------------------------------------*/ void EINT3_IRQHandler (void) { LPC_GPIO2->FIOSET = (1<<8); LPC_GPIOINT->IO2IntClr |= (1 << 5); /* Clear pending interrupt */ }
this is fair?
