Hi all
Are there any JTAG header 8051 bord that can be used with KEIL compiler? I want to avoid pricy programmers .
I want to directly download the 8051 code from KEIL to the 8051 board.
Many thanks Elico
Search here: http://www.keil.com/dd/search_parm.asp
I would suggest the Silicon Labs boards...
http://www.keil.com/dd/chips/siliconlabs/8051.htm
"I want to directly download the 8051 code"
Note that you don't actually need JTAG or even on-chip debug to do that - just ISP
second that motion.
not only do you get JTAG download, but you get JTAG debugging as well.
just a note: the SILabs 'JTAG' has the same functionality as JTAG, but is not JTAG chainable (at least not for f3x-up. I do not recall for f0x-f2x, check it if you need it).
