Hello, what I would like to do is to copy a function from SRAM to flash and decide in the main if I want to execute from flash or from SRAM. What I observed it is that if this function is calling a subroutine placed in SRAM, when I execute it from flash the jump will not be set correctly: it will try to jump to a subroutine placed in flash, but this function is located in SRAM!!! What can I do to have the correct address when I execute from flash? I tried with the PI qualifiers ropi, but it does not work... I am using a device with Cortex M4
I don't know the M4, but I believe that it resembles the M3 in this regard. Have a look at NXP sample code (are you using an NXP chip?)
search for IAP samples...
I am using xmc4500...
Alex
