Hi
I'd like to put a struct
typedef struct { U32 a; U8 b[8]; U8 c; } MyType;
MyType xdata *pMyVar;
in XRAM to a particular address section that starts at 0x1000. Therefore I added "XDATA(0x1000)" in the linker command (BL51). But unfortunately the linker doesn't place the variable to an address above 0x1000 but somewhere below instead!
But when I swap the deklaration to
xdata MyType *pMyVar;
everything works as expected! Is there a different between those two declarations? According to http://www.keil.com/support/man/docs/c51/c51_le_xdata.htm the first (not-working) variant is the correct one!
I am confused. Any ideas?
Jonathan
