Dear Colleagues,
Here's my source code:
#include <91x_lib.h> #include "masodik.h" unsigned char gpio7_out = 0; int main() { GPIO_InitTypeDef GPIO_InitStruct; TIM_InitTypeDef TIM_InitStructure; GPIO_DeInit(GPIO7); GPIO_InitStruct.GPIO_Direction = GPIO_PinOutput; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_All; GPIO_InitStruct.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStruct.GPIO_Alternate = GPIO_OutputAlt1; GPIO_Init (GPIO7, &GPIO_InitStruct); TIM_InitStructure.TIM_Mode = TIM_OCM_CHANNEL_2; TIM_InitStructure.TIM_Clock_Source = TIM_CLK_APB; TIM_InitStructure.TIM_Prescaler = 0xFF; TIM_InitStructure.TIM_OC2_Modes = TIM_WAVE; TIM_InitStructure.TIM_Pulse_Level_2 = TIM_HIGH; TIM_InitStructure.TIM_Pulse_Length_2 = 0xA000; TIM_Init(TIM3, &TIM_InitStructure); TIM_ITConfig(TIM3, TIM_IT_OC2, ENABLE); VIC_ITCmd(TIM3_ITLine, ENABLE); VIC_Config(TIM3_ITLine, VIC_IRQ,0); TIM_CounterCmd(TIM3, TIM_CLEAR); TIM_CounterCmd(TIM3, TIM_START); gpio_out = 0; while (1); }
and my interrupt handler:
void TIM3_IRQHandler(void) { /*write your handler here*/ /* ... */ gpio_out ^= 0xAA; GPIO_Write(GPIO7, gpio_out); TIM_ClearFlag(TIM3, TIM_FLAG_OC2); TIM_CounterCmd(TIM3, TIM_CLEAR); /*write any value to VIC0 VAR*/ VIC0->VAR = 0xFF; VIC1->VAR = 0xFF; }
This program should blink every 2nd pin on GPIO7 within the TIM3 interrupt handler. gpio7_out is a golbal variable. My problem is that it runs until the 1st interrupt occurs, executes it, and then it gets stuck within an endless loop on the Undefined Handler interrupt. At that time, the simulator says: Non-aligned Access: ARM Instruction at 00000298H, Memory Access at 000000F7H *** error 65: access violation at 0x000000F7 : no 'write' permission
Any ideas where am I going wrong?
BTW, I looked in the assembly at the instruction that is on the address location that the simulator complains about, it's
0x00000298 5800D000 STMPLDA R0,{R12,R14-PC}
This is probably an attempt to jump back from a sub routine (IRQ handler)
So far I managed to get it working by addin the __irq directive infront of the interrupt handling routine, like
__irq void TIM3_IRQHandler(void)
The only thing is, in that case I also have to change the definition of the function in the 91x_it.h file. I don't think that changing the given vendor's libraries is a good idea in a long term, but I still can't tell what am I missing.
Ah yes, so BTW my basic problem was, that the compiler couldn't tell that my ISR _is_ actuall an ISR, so it didnt return from the routine properly, causing an exception.
So, anyone else with this problem? It seems to be a general Keil issue...
