Hi On projects that have different data memory regions - how do you force the stack and heap into a specific region.
I am using the STM32F4xxx and there are two (default)memory regions IRAM1 and IRAM2. In the asm startup file there is:
Stack_Size EQU 0x00004000 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp Heap_Size EQU 0x00008000 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB
By default the linker is putting the stack and heap in IRAM2 and I want it in IRAM1. Not really clued up on the assembler directives. :(
While on the subject of allocation - I have tried various combinations to get 2x __attribute directives into 1X statement but the only way I can get it to work is with 2x:
SerialChannel_Typedef __attribute__((aligned)) sSerialCh1; sSerialChannel_Typedef __attribute__((section("IRAM1"))) sSerialCh1; // This works // I tried this SerialChannel_Typedef __attribute__((aligned)(section("IRAM1")))) sSerialCh1; // and this SerialChannel_Typedef __attribute__((aligned))((section("IRAM1"))) sSerialCh1; // both don't work - compiler gives errors
Any ideas?
Thanks Peter
Perhaps this article might be helpful for you:
http://www.keil.com/support/docs/3480.htm
I needed quite a time to figure out, how to use uninitialized data in C++ for STM32F4 - there are some "misguiding" articles in Internet - but the above works perfect.
... so I handled only uninitialized static global memory data - but not stack data or dynamic alloc data - but maybe it is a help for you anyway ...
