In the following code the FSMC sets up the registers BCR and BTR (taken from the STM32F400 dev board code from Keil).
// FSMC_Bank1->BTCR[(3-1)*2 + 1] = /* Bank3 NOR/SRAM timing register configuration */ // (0 << 28) | /* FSMC AccessMode A */ // (0 << 24) | /* Data Latency */ // (0 << 20) | /* CLK Division */ // (0 << 16) | /* Bus Turnaround Duration */ // (9 << 8) | /* Data SetUp Time */ // (0 << 4) | /* Address Hold Time */ // (1 << 0); /* Address SetUp Time */ FSMC_Bank1->BTCR[(3-1)*2 + 0] = /* Bank3 NOR/SRAM timing register configuration */ (0 << 19) | /* Write burst disabled */ (0 << 15) | /* Async wait disabled */ (0 << 14) | /* Extended mode disabled */ (0 << 13) | /* NWAIT signal is disabled */ (1 << 12) | /* Write operation enabled */ (0 << 11) | /* NWAIT signal is active one data cycle before wait state */ (0 << 10) | /* Wrapped burst mode disabled */ (0 << 9) | /* Wait signal polarity active low */ (0 << 8) | /* Burst access mode disabled */ (1 << 4) | /* Memory data bus width is 16 bits */ (0 << 2) | /* Memory type is SRAM */ (0 << 1) | /* Address/Data Multiplexing disable */ (1 << 0); /* Memory Bank enable */
but the registers are in address order BCR1, BCR2, BCR3, BCR4, BTR1, BTR2, BTR3, BTR4 Therefore why is Bank 3 not FSMC_Bank1->BTCR[2] for BCR3 or FSMC_Bank1->BTCR[6] for BTR3
This works but it confused me as I was trying all morning with my custom board with the following
FSMC_Bank1->BTCR[2] = FSMC_BCR1_WREN | /* Bank Write enable */ FSMC_BCR1_MWID_0 | /* Memory databus width 16bit */ FSMC_BCR1_MBKEN ; /* Memory bank enable bit */
Konrad
Doh! just looked more closely at the data sheet and they are listed BCR1, BCR2, BCR3, BCR4, BTR1, BTR2, BTR3, BTR4 but are addressed BCR1, BTR1, BCR2, BTR2, BCR3, BTR3, BCR4, BTR4
