I would like to use logic analyzer but I have a doubt. I have a demo kit with ulink-me debuger but I suspect that ulink-me is not correct device to do it.
Could somebody tell me what is the correct debuger to use logic analyzer? Ulink2 or Ulink pro?
Best regards. John Martin
please enable SWJ in the Debug Tab and select SW instead of JTAG. Then you must configure the Trace Tab with the correct CPU Frequency, i.e. Timestamps: 16, and UART Mode for ULINK2/ME.
Probably your Device needs an .ini file (selectable where you select the target driver or Simulation)
Please have a look into the MCBSTM32 projects, the i.e. the STLib Blinky there is configured for ULINK2/ME.
So I understood that Ulink-Me can be able to use with Logic Analyzer. Ok, I am going to check example.
Best regards.
Hi Have same problem Did you find any solution please?
