Returning from interrupt to a specified address in main
I'm quite new to context switch and embedded software development. I'm developing a standalone application (no OS) with aduc7026 and keil uVision3. My problem is that at the end of an uart messagge, which I must receive by interrupt, depending on the content of the messagge I've to return return in main in the state saved before entering in the ISR or I've have to return in a specified point where a funcion call is executed.
Hoping that I've been clear. Does anyone have suggestions?
Thank ìs in advance,
Matteo
  • I've have to return in a specified point where a funcion call is executed.
    Let me point out that for someone who's still quite new to the whole field of embedded SW, you hold some awfully firm beliefs about how you "have to" do things. That doesn't feel right.
    And no, you almost certainly (a) don't have to do that, nor (b) should be be trying to at this point on your learning curve. Stick to simpler designs until you really know what you're doing.
