Error:can't execute 'BIN31\ArmCC'
HI! I have actually made a program to initialize a USB port as a host in Keil uVision3.
The code i m writing will be implemented on LPC2468ARM7 board. But wen i build da same it shows dis error
I have searched a lot. Please help ,as i m stuck on dis.
  • To better understand your issue, I have a few quesitons:
    Do you have a C:\Keil\ARM\BIN31\armcc.exe file?
    Did you install the Keil tools in the C:\Keil folder?
    Which version of the Keil tools are you using?
    Can you use a newer version of the tools uv3 is pretty old now.
