Hi everyone 1>I am trying to write data in sd card 2>I am using LPC 2368. 3>I am getting response that TxFifoHalfEmpty Transmit FIFO is half full. what should I do to overcome this problem
Please Help!
Hello Sir
Thanks for your reply
I check my code again
first time it goes into MCI_IRQ handler
goes into FIFO_Init_Mask
then comes out of that function
again goes into MCI_IRQHandler
going into DATA_ERR_INT_MASKtus
MCI_DataErrorProcess
in that MCI_Tx_Underrun Error
and program stuck there
while(MCI_Block_End_Flag==1);
program stuck here
not going in TxDisable function
Can you please help me out with this.
name are according to NXP's example code.
Thank You!
Interrupt that a transmit FIFO is half-full is generated just so that the software can add more data before the FIFO gets empty.
