hello I am currently working on a project which has 20 Mhz osc. I am using LPC2368 I want CCLK should me 48Mhz Can anybody please explain me configuration required for pll registers. I have gone through NXP exel sheet according to that for my application M value is 12 N value is 1 Fcco value is 480
but when I make this changes I was not getting CCLK as 48MHz
Please Help!
So what did you get?
And are you sure you do have a 20MHz oscillator?
And are you using the configuration wizard? If not - have you taken into account that the PLLCFG register should be configured with M-1?
Thank for reply
Yup I am sure I am using 20MHz crystal N i dia M-1=12-1=11=B so i did according settings in PLLCFG
Is it necessary that Input clock frq(20Mhz) should completely divide CCLk?
No - 20MHz crystal should give perfect generation of 48MHz using a large number of PLL combinations.
What processor stepping do you have?
The original '-' stepping can't support an intermediate frequency as high as 480MHz. The errata gives a limit of max 290MHz for Fcco. But that is ancient silicon.
