I am attempting to enable a specific pin in the GIPOA. When I enter debug mode and execute the command that should enable the pin: ODR8, it does not enable. So, I tried to enable it manually using the check box in the System Viewer Window -> GPIO -> GPIOA + ODR. The check shows up for a split second then goes away. It will not allow me to change any of the check boxes.
Is there a simple solution to this?
Thank you.
