Unexpected value in R0
Hi, I'm back with more questions :)
I have a 4-element array of 4-byte bit field structures filling up my bit addressable memory. Those structures are manipulated a lot in my code. I have found that assigning a pointer to an array element and then working with it generates much less code than working with the element directly. In one piece of my code, I want to do a logical operation with a lot of 2-bit structure fields. A line that does that looks like this:
pointerToStruct->2bitField ^= pointerToStruct->2bitField << 1;
This is compiled into a lot of instructions, but the beginning looks like this:
MOV R0, 0x01
PUSH
MOV A, @R0
MOV R4, A
My program breaks at the last instruction with error 65: access violation at I:0xE7: no 'read' permission. When I look at my registers, R0 really contains 0xE7. The first instruction should have put 0x01 in R0. PUSH should not have affected it as far as I know. If I check &pointerToStruct in the watch windows, the address is really D:0x01, so this should be ok.
Any ideas about how 0xE7 ended up in my 0xE7? Is it possible that my stack overflows? If it tried to go beyond 0x7F, would it wrap around and start writing into register banks or what?
