Hello, I work at CTI Design House -Brazil (http://www.cti.org.br) and we develop a microcontroller based on the 8051. However, our microcontroller uses registers that are not available in 80C51 listed in the database. I'm having problems when I try to build the target, this case the following message appears "VER_I2CSM_TX_1B_NEW.asm (130): error A1: ILLEGAL CHARACTER IN NUMERIC CONSTANT" Here is the line indicated by the message.
mov 0E8, # 001h; </ pre>. Can someone show me the solution to this problem? Sincerely, Claudionor Santos
what about this:
MOV 0E8H,#1 MOV 0xE8,#1
Thanks, it is working now !
But have some warning messages, like that:
*** WARNING L5: CODE SPACE MEMORY OVERLAP FROM: 0000H TO: 0002H *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_START MODULE: STARTUP.obj (?C_STARTUP) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_START MODULE: STARTUP.obj (?C_STARTUP) ADDRESS: 080AH
anyhow what ARE you doing? mov 0E8, # 001h; is assembler and the error messages are from 'C' is seems like/could be that you include startup.a51 in an assembler program
it is a assembly code.
full code :
#define Result_final 0f8h ;*********** Tabela de EQU para as Variaveis em RAM VEZES EQU 8 ; conta o número de vezes de interrupçao I2C ;******************************************************************** ; ENDERECO DE DESVIO SAIDA DE RESET cseg at 0000h AJMP 200h ;******************************************************************** ; ENDERECO DE DESVIO DA INTERRUPCAO INT0 ;cseg at 0003h ;AJMP 0050h ;********************************************************************* ;******************************************************************** ; ENDERECO DE DESVIO DA INTERRUPCAO DO TIMER/COUNTER 0 ;cseg at 000Bh ;AJMP 0050h ; ENDERECO DE DESVIO DA INTERRUPCAO DO INT1 ;cseg at 0013h ;AJMP 0070h ;********************************************************************* ;********************************************************************* ; ENDERECO DE DESVIO DA INTERRUPCAO DO TIMER/COUNTER 1 ;cseg at 001Bh ;AJMP 0070h ;********************************************************************* ; ENDERECO DE DESVIO DA INTERRUPCAO DO CANAL I2CSM cseg at 02Bh ; I2CSM interruption AJMP 100h ;********************************************************************* ;********************************************************************* ; ENDERECO DE DESVIO DA INTERRUPCAO DO CANAL SERIAL ;cseg at 0023h ;serial interruption ; AJMP 0100h ;********************************************************************* ;********************************************************************* cseg at 100h MOV 0F0h, 0E8h ; MOVES STATUS REG TO ACCUMULATOR jb 0F1h, msb_interrupt ; Status Register bit 1 - E8.1 jb 0F0h, lsb_interrupt ; Status Register bit 0 - E8.0 jb 0F2h, nack_interrupt ; Status Register bit 2 - E8.2 mov R2, 0E8h cjne R2, #042h, test_lsb_interrupt ajmp msb_interrupt test_lsb_interrupt: cjne R2, #041h, test_nack_interrupt ajmp lsb_interrupt test_nack_interrupt: cjne R2, #044h, error_detected ajmp nack_interrupt error_detected: ajmp error_02 msb_interrupt: mov R0, 84h mov 0E8h, #80h ; FLAG Clear - E8 . Clear Interruption Flag inc VEZES ; Incrementa o contador de interrupçoes cjne R0, #0A2h, error_03 reti lsb_interrupt: mov R0, 85h mov 0E8h, #80h ; FLAG Clear - E8 . Clear Interruption Flag inc VEZES ; Incrementa o contador de interrupçoes cjne R0, #0F8h, error_04 setb ACC.0 reti nack_interrupt: mov R0, 84h mov 0E8h, #80h ; FLAG Clear - E8 . Clear Interruption Flag inc VEZES ; Incrementa o contador de interrupçoes cjne R0, #0F8h, error_04 setb ACC.1 reti error_02: mov 30h , R2 mov 31h , 0E8h mov Result_final, #003h ;Interrupt error error_03: mov 32h , R2 mov 33h , 0E8h mov Result_final, #003h ;Recieve error error_04: mov 34h , R2 mov 35h , 0E8h mov Result_final, #003h ;Bit 8 receive error ;********************************************************************* ; Configure 8031 ;********************************************************************* cseg at 200h SETUP_MCU: clr RS0; clr RS1; mov R0, VEZES mov A, R0 CJNE A,#0,MAIN_LOOP mov PSW, #00h ; Move o valor do reg. PSW para 00h mov IE, #0C0h ; Move o valor de C0h para IE, Habilita Interrupcao do I2CSM mov PCON, #000h mov VEZES, #001h ; inicializa o contador de interrupcoes I2C mov ACC, #000h ;********************************************************************* ; Start tranmission test ;********************************************************************* mov 0D8H, #001h ;--->>> Reg D8h não implementado I2CSM Habilitado mov 0D9h, #000h ;--->>> Reg D9h não implementado I2CSM Standard Mode D9h mov 84h, #0A2h ;I2CSM Slave Address 0xA2 , Write Mode mov 85h, #0F8h ;I2CSM Write Data 0xF8 mov R5 , 84h mov R6 , 85h mov SP, #10h MAIN_LOOP: mov R4 , 0E8h CJNE R4,#42,continue_MAIN_LOOP nop nop nop ajmp error_01 continue_MAIN_LOOP: jnb ACC.1, CHECK_I2C_LSB_INT_DONE; mov R3, VEZES ; CHECK_I2C_NACK_INTERRUPTION CJNE R3,#02,error_01 ajmp test_completed CHECK_I2C_LSB_INT_DONE: jnb ACC.0, MAIN_LOOP; mov R3, VEZES CJNE R3,#03,error_01 test_completed: mov Result_final, #001h ;Test complet sussesfuly error_01: mov 36h , R3 mov Result_final, #003h ;Bit 8 receive error END
startup.a51 included in the linking string
check the .map
thanks ,
i just could not understand when you wrote "this is ridiculous."
could you be clear ?
To answer the original question. You can modify some things in a device data base. First go to File -> Device DataBase... and open the dialog. Carefully select a device as near to your device as possible(carefully read the device descriptions). To make a copy of the existing device data base, change the name, device family and device type to your device names, etc. Modify the any data necessary and click the Update AND the the ADD button. At this point you can define the register .h files that you have created to define your register set. This is just your Regxxx.h file that you have created. You can change other device descriptions as necessary.
Now the real hard part. If you have peripherals not common to the device that you select to change, you must write your own peripheral types using the AGSI and/or the AGDI features in this toolset. These new tools will be written in C++ external to the Keil Tools and you will create a new .dll for your simulator. Templates are availble on this website.
All of this is described in detail in the PK51 User's Manuals at this website. You must read and study these manuals carefully to implement any serious changes to the Device Database.
Good Luck. You will need it.
Bradford
This is described in the uVision Manual:
http://www.keil.com/support/man/docs/uv4/uv4_ca_cpu_ndatabase.htm
http://www.keil.com/support/man/docs/uv4/uv4_c_dd_parameters.htm
