Hi I how to extract the data for multiple input to adc port in lpc2138 . Here is the code for initialization of the adc and tell me how to extract the data for both the adc
void adc_ini(void) { PINSEL1 = 0X05000000; //pin 13 p0.28 and p0.29 adc 0 channel 1 and 2 PCONP |= 0X00001000; //select adc 0 bit 12 AD0CR &= 0X00000000; AD0CR |= 0X00200206; // WITH PCLK 12/(2+1)=4MHZ ADC0 CHANNEL 1 and 2 PIN 13 and 14 AD0INTEN &= 0x00000000; //Completion of a conversion on ADC channel 0 will not generate an interrupt. } void adc_data(void) { AD0CR |= 0x01000000; /* Start A/D Conversion */ while((AD0DR & 0x80000000)==0); //until bit 31 is high (DONE) val = AD0DR; //read a/d data register adc_val = ((val >> 6) & 0x3FF); // Extract AD result }
How to modify for extracting the data from both the data register ?
Thanks in advance
This what you have used
AD0CR |= 0X00200206; // WITH PCLK 12/(2+1)=4MHZ ADC0 and 1 CHANNEL 1 PIN 13
And this is what the user manual says for AD0CR: b7:0 Selects which of the AD0.7:0/AD1.7:0 pins is (are) to be sampled and converted. For AD0, bit 0 selects Pin AD0.0, and bit 7 selects pin AD0.7. In software-controlled mode, only one of these bits should be 1 . In hardware scan mode, any value containing 1 to 8 ones. All zeroes is equivalent to 0x01.
You should enable one channel at a time.
Alex
Hi If i wanted to monitor two channels for different inputs . what change i should made in the code.
If software conversion mode can only start the conversion for one (1) channel, and you want to use software conversion mode but use more than one channel - don't you think that you must then use the software conversion mode multiple times?
So what would then be the logical modification of the source code?
And exactly how confusing is it to now have two threads that concurrently debates the same problem, after you decided to create two identical threads? Why didn't you post a link in one thread saying that all continued debate should happen in the other - linked - thread?
