usb bulk transfer
Hello Sir,
I am making a receipt printer for point of sale application using LPC2368 controller. I want to use USB interface for receiving data from computer to printer.I am using bulk transfer for data receiving and sending data. I started using Keil USB HID source code example and converted this source code for bulk transfer using following changes in configuration descriptor and few other changes
const UWORD8 USB_ConfigDescriptor[] = {
/* Configuration 1 */
  USB_CONFIGUARTION_DESC_SIZE,       /* bLength */
  USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */
  WBVAL(                             /* wTotalLength */
    1*USB_CONFIGUARTION_DESC_SIZE +
    1*USB_INTERFACE_DESC_SIZE     +
    2*USB_ENDPOINT_DESC_SIZE
  0x01,                              /* bNumInterfaces */
  0x01,                              /* bConfigurationValue */
  0x00,                              /* iConfiguration */
  USB_CONFIG_BUS_POWERED /*|*/       /* bmAttributes */
/*USB_CONFIG_REMOTE_WAKEUP*/,
  USB_CONFIG_POWER_MA(100),          /* bMaxPower */
/* Interface 0, Alternate Setting 0, MSC Class */
  USB_INTERFACE_DESC_SIZE,           /* bLength */
  USB_INTERFACE_DESCRIPTOR_TYPE,     /* bDescriptorType */
  0x00,                              /* bInterfaceNumber */
  0x00,                              /* bAlternateSetting */
  0x02,                              /* bNumEndpoints */
  USB_DEVICE_CLASS_PRINTER,          /* bInterfaceClass */
  0x01,                              /* bInterfaceSubClass */
  0x02,                             /* bInterfaceProtocol */
  0x62,                              /* iInterface */
/* Bulk In Endpoint */
  USB_ENDPOINT_DESC_SIZE,            /* bLength */
  USB_ENDPOINT_DESCRIPTOR_TYPE,      /* bDescriptorType */
  USB_ENDPOINT_IN(2),                /* bEndpointAddress */
  USB_ENDPOINT_TYPE_BULK,            /* bmAttributes */
  WBVAL(0x0040),                     /* wMaxPacketSize */
  0,                                 /* bInterval */
/* Bulk Out Endpoint */
  USB_ENDPOINT_OUT(2),               /* bEndpointAddress */
  0,                                 /* bInterval */
/* Terminator */
  0                                  /* bLength */
Computer recognize my board usb device as a USB printing support successfully. I just want to know that is there is any class descriptor like HID class descriptor for printer or not?
And also I want to know that Is there is any host application to check bulk out transfer .
Thanks & Regards
Rohit
  • Your printer descriptors seem fine.
    Printer class doesn't have any extra descriptor, unlike HID report descriptor.
    Instead, GET_DEVICE_ID request returns Printer "Device ID" string, which describes printer's property.
    Windows has a default INF file for "Generic" printers. To install your printer silently (ie. without any INF file), apply this Device ID for "Generic Text Only".
    typedef struct __attribute__ ((packed))
        BYTE size_h, size_l;
        BYTE str[];
    } T_prn_Device_ID;
    static const T_prn_Device_ID prn_Device_ID =
       0x00, 12 + 24 + 11 + 12 + 30,          // size of string, two-bytes, MSB first
       {                                      // these strings are concatenated by compiler
           "MFG:Generic;"                     //   manufacturer (case sensitive)
           "MDL:Generic_/_Text_Only;"         //   model (case sensitive)
           "CMD:1284.4;"                      //   PDL command set
           "CLS:PRINTER;"                     //   class
           "DES:Generic text only printer;"   //   description
    I posted this tip of USB printer on these forum threads,
    USB Printer Class(Client, not Host) - Microchip USB forum
    " href= "e2e.ti.com/.../217001.aspx"> e2e.ti.com/.../217001.aspx
    [USB printer spec]
    "Printer Device Class Document 1.1"
    www.usb.org/.../usbprint11.pdf
    Printer port is accessed over WinAPI.
    - How to send raw data to a printer by using Visual C# .NET
    support.microsoft.com/.../en-us
    - HOWTO: Send Raw Data to a Printer by Using the Win32 API
    - How to send raw data to a printer by using Visual Basic .NET
    Tsuneo
        BYTE str[];
    } T_prn_Device_ID;
    [USB printer spec]
    Tsuneo
