USB peripheral through SPI interface
I am using the SPI interface to connect the MAX3420e with lpc11A14 mcu and am enabling the GPIO pins of the MAX3420e . Am not finding any signal on the SCLK line of the device. Below mentioned is my code. Kindly help me to achieve the result.
#include "lpc11Axx.h"
#include "gpio.h"
#include "spi.h"
#include "type.h"
** Function name:               SSP_IOConfig
** Descriptions:                SSP port initialization routine
** parameters:                  None
** Returned value:              None
void SSP_IOConfig( void )
        LPC_SYSCON->PRESETCTRL |= (0x1<<0);
        LPC_SYSCON->SYSAHBCLKCTRL |= (0x1<<11);
        LPC_SYSCON->SSP0CLKDIV = 0x1;                        /* Divided by 1 */
        LPC_IOCON->PIO0_22 &= ~0x07;     /*  SSP I/O config */
        LPC_IOCON->PIO0_22 |= 0x01;          /* SSP MISO */
        LPC_IOCON->PIO0_19 &= ~0x07;
        LPC_IOCON->PIO0_19 |= 0x03;          /* SSP MOSI */
        LPC_IOCON->PIO0_20 &= ~0x07;
        LPC_IOCON->PIO0_20 |= 0x01;          /* SSP CLK */
        /* Enable AHB clock to the GPIO domain. */
        LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6);
        LPC_IOCON->PIO0_18 &= ~0x07;             /* SSP SSEL is a GPIO pin */
        /* port0, bit 18 is set to GPIO output and high */
        GPIOSetDir(PORT0, 18, 1 );
        GPIOSetBitValue( PORT0, 18, 1 );
** Function name:               SSP_Init
** parameters:                  None
void SSP_Init( void )
  uint8_t i, Dummy=Dummy;
  /* Set DSS data to 8-bit, Frame format SPI, CPOL = 0, CPHA = 0, and SCR is 15 */
        LPC_SSP0->CR0 = 0x0707;
        /* SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 */
        LPC_SSP0->CPSR = 0x2;
        for ( i = 0; i < FIFOSIZE; i++ )
          Dummy = LPC_SSP0->DR;              /* clear the RxFIFO */
                /* Master mode */
        LPC_SSP0->CR1 |= 2;
** Function name:               SSP_Send
** Descriptions:                Send a block of data to the SSP port, the
**                                              first parameter is the buffer pointer, the 2nd
**                                              parameter is the block length.
** parameters:                  register address, register value
void SPISend( unsigned char Radd,unsigned char Rval )
                uint8_t Dummy=Dummy;
                Radd|=0x02;
                /* Move on only if NOT busy and TX FIFO not full. */
                while ( (LPC_SSP0->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF );
                LPC_SSP0->DR = Radd;
                while ( (LPC_SSP0->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE );
                LPC_SSP0->DR = Rval;
                return;
unsigned char SPIReceive(unsigned char Radd)
        unsigned char SPIRECV = 0;
        Radd&=0xFF;
        while ( LPC_SSP0->SR & SSPSR_BSY );
        LPC_SSP0->DR = 0xFF;
        SPIRECV = LPC_SSP0->DR;
        return SPIRECV;
**                           Main program
#define SystemCoreClock 12000000UL
#define IOPIN     0xA0
#define PINCTL    0x88
#define USBCTL          0x78
void delay_ms(int y);
uint8_t destination = 0x00;
uint8_t data = 0xF2;
uint8_t f_duplex = 0x10;
uint8_t chip_res = 0x20;
uint8_t dis_reset = 0x00;
unsigned int test;
void delay_ms(int y)          // argument y gives the delay in ms, approximately.
   int x,z;
   for(x = 0; x < 60; x++)
      for(z = 0; z < y*100; z++)
/* Main Program */
int main (void)
  SystemInit();   // for initializing clocks
        LPC_IOCON->PIO0_26 = 0x00;
        UARTInit(9600); // for serial & Printf communication
  /* Set port 1_0 to output */
  GPIOSetDir(0,26,1);
        SSP_IOConfig(); // IO Configuration for EM783-SPI
        SSP_Init();     // Initialize the registers in SPI
  GPIOSetBitValue(PORT0,18,0);   // Slave select
        SPISend(PINCTL,f_duplex);         // Register 17
        delay_ms(1);
        SPISend(USBCTL,chip_res);               // Register 15,  Reset the chip
        SPISend(USBCTL,dis_reset);              // Register 15,  disable Reset the chip
        delay_ms(1);
        SPISend(IOPIN,data);                     // Register 20, set the GPIO pin
        delay_ms(1);
        destination = SPIReceive(PINCTL);       //      Reading the register 20
  while (1)                                /* Loop forever */
                //test = getkey();
                //sendchar(destination);
                /*if(destination== 0x00)
                        GPIOSetBitValue( 0, 26, 0 );
            delay_ms(20);
      GPIOSetBitValue( 0, 26, 1 );
            delay_ms(20);
                else
