hi,
i found that there is a mistake in the delay i have provided,after a start bit a half-bit delay has to be given.and after data bits only a full bit delay is given.am giving a full bit delay for all..and i doubt the timer delay generation is buggy or not.to be exact i loaded TH0=0xFD; to get a 9600 baud rate..for a half bit delay i might be going for conventional loops to generate one..
Did you mean to post this as a Reply in some other thread?
It makes no sense on its own.
Of course it makes a difference if you are transmitter or receiver side.
When transmitting, you can work in full-bit delays.
When receiving, you must poll the data much quicker to figure out the exact position for start bit - or use interrupt-driven detection of start bit.
Then you need to decide where to sample your received data bits. Either by having a suitable delay, or by having interrupt-driven code measure all detected data line changes with suitable time resolution.
But I did mention this in an earlier post.
Another thing - a good UART samples the data signal multiple times within every bit cell and takes a majority vote to decide if the bit is high or low. An interrupt-driven receiver may on the other hand suffer large number of interrupts if the signal is noisy.
