I am aware of tools like SRecord but they don't solve the problem of image checksum verification (image programmed by ULINK) during start-up, because they cannot patch an .axf file correctly (AFAIK) - thus boot will fail due to checksum verification failure (if programming via ULINK). Can any component of the tool chain generate a checksum that is added at the very end of an image so that a verification will work whether the image was programmed via ULINK or a bootloader?
Thanks in advance
I did find this thread:
http://www.keil.com/forum/17939/
I can reserve 2 or 4 bytes in the image for CRC to be inserted later. Need a PC tool for that that will be triggered at the end of the build - can write my own.
"I can reserve 2 or 4 bytes in the image for CRC to be inserted later. Need a PC tool for that that will be triggered at the end of the build - can write my own."
That's exactly what I've done. A little application (in C) that is executed as part of the build process. It reads in the file from the linker, appends a 4 byte CRC, and writes it back.
But, there again, I always use binary images. Never ventured into doing something on ELF files.
I can probably create a "development" vs. "release" targets for project components - the "release" does scatter loading that takes into account the last 4 bytes, making it longer to load into the debugger, but normally it would have the watchdog enabled anyway. Thanks.
