Hi guys,
I wrote a function that generates a set of constants to be used in assigning a delay value for each pulse for driving a stepper motor. My code just stop at the first iteration of the code, please have a look below and tell me what you think the cause is. I am thinking it is because of the complexity of the math operation, am I right? Thank you all in advance.
#include"constants.h" #include<math.h>
const unsigned long C0_constant;
unsigned long calc();
void stepper_loop() { unsigned long constants_array[1772]; unsigned long Cn_vals; unsigned int j;
unsigned long *Px; // decalre the pointer first Px= constants_array; //make the pointer points to the address of first element in the array
for(j=0; j<1772; j++) {
Cn_vals=calc();
constants_array[j]=Cn_vals; Px++; // increment the pointer to point to the next element in the array } }
unsigned long calc() { static unsigned long K_val; static unsigned int step; unsigned long Delta_T; unsigned long value_sqrd; unsigned long C0_constant;
if(step==0) { value_sqrd=2*Alpha/angular_accel;
C0_constant=sqrt(value_sqrd/period); // program stop at this line. K_val=C0_constant; }
step=step+1;
K_val=K_val-(2*K_val/(4*step+1)); Delta_T=K_val; return(Delta_T); }
#include<math.h>
#ifndef constants_H #define constants_H
#define PI 3.14159 //#define PI 3 #define Alpha 0.000625*PI //#define Alpha 5*PI #define period 0.00000004 //#define period 4 #define angular_accel 8.6955
#endif
Are you sure about the variable types you are using?
results to 0.000451611847161 which is truncated to 0 since the result is stored in an unsigned long.
The line following this is useless , it calculates the square root of 0
Alex
