Stack Location (Cortex-M)
Hi guys,
I'm wishing to move the location of the stack but how is this possible? In the startup.s I have
                EXPORT  __initial_sp
Stack_Size      EQU     0x00000200
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
However there's no option for the location and nothing specific for the stack appears to show up in the generate scatter file.
I'm a little lost and would appreciate any help.
Many thanks
  • The Cortex chip is picking up the location of the stack before entering the code in the startup file. It is doing that by looking within the interrupt vector table. This is a neat trick that means the Cortex chip could start to run C code (minus the availability of initialized variables etc) directly from start.
    Your startup file probably have something looking like:
    __Vectors       DCD     __initial_sp              ; Top of Stack  <=== read by processor
                    DCD     Reset_Handler             ; Reset Handler
                    DCD     NMI_Handler               ; NMI Handler
                    DCD     HardFault_Handler         ; Hard Fault Handler
                    DCD     MemManage_Handler         ; MPU Fault Handler
    Ant that __initial_sp got computed from:
    __initial_sp
    More interesting questions here - why do you want to move the stack? And where do you want it moved?
    __initial_sp
