I am using ADUC842.
Continuous pulse is being fed at port P2.6
I need to calculate rising edges of the pulse for 10ms time interval..
how should i proceed?
pls help.
Regards Mayuri
how should i proceed? 1) put an inverter between the unit that generates the edge and the uC pin. 2) analyze the problem 3) read the datasheet 4) write a simple first code that turns on a LED on an edge 5) write the final code 6) test it 7) deliver it
This will be a hardware change.
Can you suggest me a solution wherein there is no hardware change.
Change should be respect to the code.
Can you suggest me a solution wherein there is no hardware change. '51 interupts can only be configured for falling edge.
can't you do the same with falling edges
Now the scenario is different..
I have continuous train of pulses wherein pulse of 14 ms duration is always repetitive..
Its like if there are X number of highs in 14ms repetitive duration then the module is detected if not den it is not detected.. so now i need to count number of highs.....
Here is the code i have written
TMOD = 0x10;//CONFIGURING 14 ms TIMER TH1 = 0xFA;//CONFIGURING 14 ms TIMER
TL1 = 0x89;//CONFIGURING 14 ms TIMER
while (1) //IN CONTINUOUS LOOP { do { TR = 1; //START TIMER if (P1 == 1) //checking for high { count++; //if there is a high den increase the count } if(count == 5) //checking for count { display(); //module is detected and hence display } while (TF1 == 0); TR1 = 0;//stop timer TF1 = 0;
Is this logic fine?
Your logic don't even seem to agree with your english text.
You say a pulse is 14ms "pulse of 14 ms duration is always repetitive". But then you seem to want to write code that counts number of pulses within a single 14ms period.
Was it hurtful to follow the instructions how to post source code?
Your loop don't contain any clear of a variable so your count value will just go up and up and up and up - what logic is that?
Checking if a signal is high isn't the same as knowing there have been a pulse.
Next thing - high or low flank doesn't matter. Any sequence of many pulses must still have multiple flanks of each type. Why don't you want to let the hardware count flanks?
"Is this logic fine?" What does the debugger tell you?
pulse of 14 ms is repetitive means i m getting continuous signal of 14ms duration which has a unique pattern...
I am planning to use ISR...
Sorry - you are still not clear.
On one hand, you talk about "pulse" (that seems to be 14ms long). Then you talk about "continuous signal". Then you say these 14ms have a "unique pattern".
So you have a single pulse 14ms long? Or a time window of 14ms with either zero or one pulse? Or a time window of 14ms with zero or many short pulses? Or either "silence" or a continuous sequence of 14ms long pulses? Or something else???
Slow down, and write enough text that we can understand you. Or graph it. Below would be an example of an "unique pattern" within a 14ms window:
+--+ +--+ +--+ +--+ | | | | | | | | -+ +--+ +--------+ +--+ +------------------- |---------- 14 ms----------|
ya r8..this is the pattern i m getting...this pattern is repeting again and again
TMOD = 0x05; // TIMER 0 , MODE 1 SELECTED TL0 = 0x89; // 14 ms timer TH0 = 0xFA; // 14 ms timer
while(1) { do { TR0 = 1;
P1 = TLO;//reading the count in port } while(TF0 == 0); TR0 = 0; TF0 = 0; } } I am using timer as counter for counting pulses.... Is this logic fine?
I guess you just refuses to read up on how to post source code on this forum.
So we better refuse to read what you post too.
Didn't you notice the different look in my post?
#include <stdio.h> void main(void) { printf("Hello world!\n"); for (;;) ; }
And by the way - why don't you test your code instead of asking "is this logic fine"? Code having so few lines really do not take too long to test. You just can't develop applications without debugging.
Most probably not. Two pulses a pause and two pulses within a 14ms window? Most probably not.
But more importantly - you still haven't described the difference between the two states you want to detect. 1) what the signal looks like when the module is active 2) what the signal looks like when the module is not active 3) how short time the module may be active as shortest 4) how short time the module may be inactive as shortest 5) how fast you need to be able to detect when it gets activated 6) how fast you need to be able to detect when it gets deactivated 7) if there can be glitches in the signal, requiring any form of filtering of the signal (sw/hw) 8) if there is a silent phase where it matters if the signal stays high or low
In short - you have given us zero information about exactly what a program should look for. Zero as in: no information anyone who reads this thread can use. Because the facts you have given are mismatching.
You sometimes talks about a measurement window of 10 ms. Then you suddenly talk about 14 ms. You sometimes talks about pulses being 14ms long. Then suddenly about having multiple pulses within 14 ms. You sometimes talks about _needing_ rising edges to be processed. Then suddenly claims a scenario where it doesn't matter if you look for rising or falling edges. You sometimes talks about a continuous pulse train and then suddenly claims you see a specific pattern.
Do walk through the 8 bullets above, and give specific and carefully worded answers to each and every one of them. If not for us, but at least for yourself. It's impossible to implement a program without a specification. If you don't know what problem to solve, you can't develop an algorithm that solves the problem. And you can't do any testing of the written code since you have no metric to measure if the code is correct or not.
Why would you think the logic is fine?
You can make it a two timer/counter solution or a one timer/counter solution.
______ _______ | | | | | | | | __| ________| |
0110011 is the pattern i am getting which is having total duration of 14 ms.. The above mentioned pattern is repeating again and again..
Hardware working:
If the module is able to sense above signal then module has detected the probe from where above signal comes.
If module is able to sense some other pattern then module has not detected the probe...
So for module to sense this signal,i am counting number of pulses using timer as counter.
I am srry... i cudnt draw the waveform properly.. pls pardon
