I have studied I2C in a number of sites but I can't find the error in my program. I'm trying to write 'A' and read it from the eeprom.
#include<at89x51.h> #include<lcd.h> #include<delay.h> #include<intrins.h> //For using [_nop_()] #define ack 1 #define nack 0 sbit sda=P1^0; sbit scl=P1^1; void I2C_start() // Start I2C { sda = 1; _nop_();_nop_(); scl = 1; _nop_();_nop_(); sda = 0; _nop_();_nop_(); scl = 0; _nop_();_nop_(); } void I2C_stop() { sda = 0; _nop_();_nop_(); scl = 1; _nop_();_nop_(); sda = 1; _nop_();_nop_(); } void I2C_writebit(unsigned char Data) { unsigned char i; for(i=0;i<8;i++) { sda = (Data & 0x80) ? 1:0; scl = 1; _nop_(); scl = 0; Data<<=1; } scl= 1; _nop_();_nop_(); scl = 0; } unsigned char I2C_readbit(char ackbit) { unsigned char i, Data=0; sda = 1;// not clear Y SDA is out here for(i=0;i<8;i++) { scl = 1; Data<<=1; Data = (Data | sda); scl = 0; _nop_(); } if(ackbit) sda = 0; else sda = 1; _nop_();_nop_(); scl = 1; _nop_();_nop_(); scl = 0; return Data; } void I2C_writebyte() //save in EEPROM { I2C_start(); I2C_writebit(0xA0); //device address I2C_writebit(0x00); //word address I2C_writebit(0x41); //send data A I2C_stop(); } void I2C_readbyte() { unsigned char i; I2C_start(); I2C_writebit(0xA0); I2C_writebit(0x00); I2C_start(); I2C_writebit(0xA1); //device address i=I2C_readbit(nack); I2C_stop(); lcd_data(i); // I have written a separate LCD.h file for this function } void main() { unsigned short int LCDL1=0x80; unsigned short int LCDL2=0xc0; lcd_ini(); I2C_writebyte(); I2C_readbyte(); while(1) { delay_msec(1); } }
Got a Scope? It makes this easier. Do You have another way to read or write the chip? Then you can figure out if you have a read or write problem.
You Code could use some Comments.
But You are not reading back the ACK bit when you write. That is a 9th bit. It will also tell you the Chip is getting your writes.
Pls reply
