I want to create delay functions in a separate c file. The code should be as perfect as possible without using internal timer. I read somewhere that 'Calling the routine takes about 22us' Though 22uS may be different for my cpu clock, if possible this factor should also be taken into account.
I am using 89S52 with 24Mhz crystal. I tried following code.
void usdelay(unsigned int us){ while (us--){ _nop_(); //0.5uS single-cycle instruction delay _nop_(); //0.5uS single-cycle instruction delay } } void msdelay(unsigned int ms){ unsigned long tm = 1000*ms; while (tm--){ _nop_(); //0.5uS single-cycle instruction delay _nop_(); //0.5uS single-cycle instruction delay } } void secdelay(unsigned int sec){ unsigned long tm = 1000*sec; while (tm--){ msdelay(1); } }
The problem is that the uS & ms delays are proper (may be - I have not measured them), but it takes very long to finish secdelay with 1 sec timing. Please HELP.
what about the time the while() takes? look at the disassembly illusions about the tine a C construct takes are always false
if you want precise timing 1) write it in assembler 2) remember the time the call and parameter transfer takes
