Hello Sir/madam,
Please give notes about how to use reset pin (pin no.9 of at89s52) as an output ( with help of a watchdog timer ).
Notes detail may be there in asm format
I expect your reply,
L.Sethupathi
page 5
Reset input. A high on this pin for two machine cycles while the oscillator is running resets the device. This pin drives high for 98 oscillator periods after the Watchdog times out. The DISRTO bit in SFR AUXR (address 8EH) can be used to disable this feature. In the default state of bit DISRTO, the RESET HIGH out feature is enabled.
