Hello everybody,
I am very new to C language. In my project I get data serially from a port pin. I want to save the first 8 bits to one variable, another to second & so on. In all I want to save 32 bits in 4 bytes. Can you suggest C code.
I know it in assembly by using RRC or RLC, but how to achieve it in C?
You can try a "bit" array:
#ifndef BIT_ARRAY_H #define BIT_ARRAY_H #include <limits.h> #define CHAR_BIT 8 #define BITMASK(b) (1 << ((b) % CHAR_BIT)) #define BITSLOT(b) ((b) / CHAR_BIT) #define BITSET(a, b) ((a)[BITSLOT(b)] |= BITMASK(b)) #define BITCLEAR(a, b) ((a)[BITSLOT(b)] &= ~BITMASK(b)) #define BITTEST(a, b) ((a)[BITSLOT(b)] & BITMASK(b)) #define BITNSLOTS(nb) ((nb + CHAR_BIT - 1) / CHAR_BIT) #endif
usage:
BITSET(g_nand_flash_defective_physical_blocks, l_logical_block ) ; if (BITTEST(g_nand_flash_defective_physical_blocks, l_logical_block ) ) { }
Array definition:
uint8_t g_nand_flash_defective_physical_blocks[BITNSLOTS(NANDFLASH_BLOCKNUM)] ;
