C206 warning & C267 error while using atoi function
Hello everybody,
First of all I thank you all. With the help of you people I have started programming in C. I have completed my first project in C.
Now in my another project, I used the atoi function. I am getting warning & an error like-
MAIN.C(255): warning C206: 'atoi': missing function-prototype
MAIN.C(255): error C267: 'atoi': requires ANSI-style prototype
If I use the function without any argument, I get no errors. I have included the function prototypes, some of my code is as..
void data_rcvd_proc()
        char *recd_cmd;                         // command part of the string
        unsigned char *recd_dat;                // data part of the string
        unsigned char idata tmp_data[17];
        ES=0;                                                   // disable serial interrupt
/*      SET DATA        */
        if (strpos (RxBuffer, '=') != -1){                      // if '=' found
                recd_cmd = strtok(RxBuffer,"=");
                recd_dat = strtok(NULL,"+");
                if(strcmp(recd_cmd, "DELAY_TIME")==0){
//                      delay_time = atoi(recd_dat);            //atoi converts ascii number string into integer
                else if(strcmp(recd_cmd, "UP")==0){
//                      up_time = atoi(recd_dat);               //atoi converts ascii number string into integer
                else if(strcmp(recd_cmd, "Down")==0){
                        up_time = atoi();                       //atoi converts ascii number string into integer
Pleas help! I cannot understand the problem because in my previous project I HAD EXACTLY USED THE SAME WAY & IT WAS WORKING PERFECTLY , Thanks.
