I'm using the LPC1788 Cortex M3 ADC and I get intermittent unexpected ADC interrupts. In the following code, I will eventually get an ASSERT. I tried reading the appropriate channel data register thinking it may clear it.
When I get the ASSERT: globalDataRegister is 0x0100AF60 (no done flag, no overrun flag, but channel 1 has data) globalStatusRegister is 0x00010002 (channel 1 done flag, no overrun flag, A/D interrupt)
I set up the interrupt:
int adcChannel = 1 LPC_ADC->CR |= ADC_CR_CH_SEL(adcChannel); // select channel uint32_t adcReading = LPC_ADC->DR[adcChannel];// clear channel interrupt by reading it LPC_ADC->INTEN |= _BIT(adcChannel); // enable interrupt for channel LPC_ADC->CR |= ADC_CR_START_NOW; // start next conversion
The interrupt Service Routine:
void ADC_IRQHandler (void) { // read channel causing interrupt, its value, its done flag and its overrun flag uint32_t globalDataRegister = LPC_ADC->GDR; if ( (globalDataRegister & 0x80000000) == 0 ) { uint32_t globalStatusRegister = LPC_ADC->STAT; ASSERT ( (globalDataRegister & 0x80000000) == 0x80000000 ); return; } uint32_t adcChannel = (globalDataRegister >> 24) & 0x7; // interrupt is not cleared unless data register is read ??? uint32_t adcReading = (globalDataRegister >> 4) & 0xFFF; // uint32_t adcReading = (LPC_ADC->DR[adcChannel] >> 4) & 0xFFF; readingTable[adcChannel] = adcReading; LPC_ADC->CR |= ADC_CR_START_NOW; // start next reading }
